1951 M Electrical problem
Posted by Jerry Deimerly on July 06, 2006 at 11:36:37 from (205.188.116.133):
I bought a 1951 M in January. It had been starting fine, but this morning it will barely crank over. It’s still a 6 volt system, but had a new oversized Interstate battery when I got it. The metal case had been cut at some point to accommodate the larger battery. I was looking at the diagram, “Electrical Schematic for Farmall H/M Stock 6 volt w/cutout by wrm Aug 03” and noticed on my tractor the negative battery terminal is grounded to the tractor and the positive cable runs to the starter switch and then on to the starter. Now I’m wondering if that is causing a charging problem. But, if the cables are reversed at the battery, would the starter still rotate properly? (I figured it would run backward). Would that damage the generator or just keep it from charging? Can I simply reverse the cables at the battery so I have a positive ground and negative to the starter switch as the diagram shows or is there more I need to do to avoid possible damage (or is it already done?) If so what are the likely problem areas. Thanks in advance for all your help.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
