Wire Color code for M
Posted by Paul G. in Mn on July 06, 2006 at 16:03:07 from (206.183.179.215):
I have a real early 1939 and getting the wireing back in shape. I have a copy of the wire diagram and trying to get the colors right. I have 3 wires running tward the generator, a heavy blue one, yellow and black. I am guessing the blue and yellow go to the generator and the black went to the mag. I am guessing to that this harness has been replaced and that I should get rid of the black wire as this would have the cable to ground the mag. the Wire to the lights was black right? but what color was the wire running to the starter switch? Also what are the possitions on the light switch? I have off in the first position, nothing on second position, front and rear on the third position but front lghts seam dimmer then the forth positon were I also have front and rear lights
