Re: Wire Color code for M
Posted by CNKS on July 06, 2006 at 17:13:32 from (204.249.178.138):
In Reply to: Wire Color code for M posted by Paul G. in Mn on July 06, 2006 at 16:03:07:
If I had a scanner I would send you the diagram out of the Operator's manual. I type slowly and there is a good chance of mistakes if I try to do it manually. Many other things in the manual you wouldn't know about otherwise. The link is to Bob M's diagrams, it will have one at least similar to what you have, but there are no colors, you will have to trace the wires. As to the switch, what you have is LHDB: Low charge, High charge, dim, bright. This is for a cutout relay on the generator, which your 39 originally had. If it now has a voltage regulator, L and H are the same, as the voltage regulator ones simply had off, dim, bright. If your tractor is wired correcly, the rear light is not affected by the dim position.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
