Re: M won't wind up- strange troubles
Posted by ChadS on July 07, 2006 at 08:35:40 from (66.228.96.171):
In Reply to: M won't wind up- strange troubles posted by the Unforgiven on July 06, 2006 at 20:50:07:
Let me see if I understand this,,,,, Your running no governor,, and when you open the throttle plate, by hand,,, nothing happens??? Is the plate jammed stuck shut? Does it sound like its taking a huge breath when you open the throttle, and fall off? If you got fuel from the tank to the bowl, you may need to rejet the carb bowl larger to give it more fuel,,, Chad
