M won't wind up- strange troubles
Posted by the Unforgiven on July 06, 2006 at 20:50:07 from (199.184.119.22):
Saw an M today that the neighbors did a valve and ring job on. When they fired it up, it would not respond to the throttle and needs a lot of choke to keep running. They thought the governor linkage was goofed-up so they unhooked it so you can run the throttle shaft with your finger, no difference, you open it wide open and the engine doesn't notice, it just keeps idling, and sounds good. Something screwed up bad in the carb, right? They drove a good M up to the shop. pulled the carb off, and put it on the tractor in question, and it runs the same, starts right up, nice idle, open the throttle by hand and nothing, no sputter, no cough, no rev-up, just smooth idle. Can't find any vacuum leaks. Gasoline manifold looks good. Any ideas? Thanks, Bill
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
