Re: IH 2000 loader on a farmall 460, will it fit?
Posted by Weldon K on July 16, 2006 at 14:40:48 from (71.28.78.138):
In Reply to: IH 2000 loader on a farmall 460, will it fit? posted by Isaac Mempa on July 16, 2006 at 12:36:19:
2000 Loaders will fit on 460 tractor if the loader has correct front and rear mounting parts. The loader on a 424 cannot be installed on a 460 "as is".A 2000 loader on a 424 has very much different front mounting brackets from that used on a 460. Also the loader frame used on a 424,I believe,may not be as long as the one needed for a 460 .And, the subframe to rear axle housing attachments are different, too. All this info from Operator's manual for 2000 loader.
