Hydraulic rams for 3 pt
Posted by SDE on July 21, 2006 at 15:09:41 from (69.179.10.148):
Took two one-way rams off a New Idea corn picker, to use on my 3pt. They each have threaded nuts on the shaft, for adjusting the travel length. They also have loose "collars" on the shaft which reduce the stroke to 3 and one half inches. How can I get these off? The end clevis is threaded on, and will come off easy, but does the adjusting nut thread on to the shaft also? If so,how do you hold the shaft, to unthread it, without damaging the shaft? SDE
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
