Re: Hydraulic rams for 3 pt
Posted by Janicholson on July 21, 2006 at 16:02:21 from (66.173.50.60):
In Reply to: Hydraulic rams for 3 pt posted by SDE on July 21, 2006 at 15:09:41:
If the adjusting nut is loose enough to adjust, it should be looser than the clevis. If it si not, I would pinch the shaft in a vice with sheets of 1/8" aluminum as buffers on the teeth. If still troublesome, set the nut on an anvil, and use a sharp cold chisel to put a serious groove in three of the flats of the nut. Skip a flat between each groove. Strike perpendicular to the shaft, not along it. The nut will swell and be free on the threads. JimN
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
