Re: Farmall A 1939 pet/kero
Posted by City-Boy McCoy on July 23, 2006 at 03:54:12 from (65.0.158.70):
In Reply to: Farmall A 1939 pet/kero posted by Gynther65 on July 23, 2006 at 03:20:01:
Your tractor has to have three things to run: fuel, spark and compression. So, first find out if you are losing your fuel supply or your spark. When it quits, check to see if you have spark right then. If it does, see if the plugs are bone dry. Go from there. mike
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
