Farmall A 1939 pet/kero
Posted by Gynther65 on July 23, 2006 at 03:20:01 from (124.176.238.101):
I have been trying to get my Farmall A (Magneto ) to run properly for some time.
Originally it started fine but would stop after about 2 minutes or when it got warm.
We have rebuilt the carby and installed a new coil and condensor ( the points are ok ).
After ensuring the timing was ok as per book It started first go after 15 months ran for two minutes perfectly and abruptly stopped and will not restart.
Any ideas appreciated ............Paul.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
