Re: Farmall A 1939 pet/kero
Posted by Gynther65 on July 23, 2006 at 04:33:12 from (124.176.238.101):
In Reply to: Re: Farmall A 1939 pet/kero posted by El Toro on July 23, 2006 at 04:10:30:
Thanks guys,
Hal when the coil is removed from its housing there is loads of magnetism in magnets however when coil is inplace there is practically none.
Do you mean the Kill switch should be in the engine run or engine off position ?
Thank you..............Paul
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
