Re: Farmall A 1939 pet/kero
Posted by El Toro on July 23, 2006 at 04:10:30 from (64.12.116.65):
In Reply to: Farmall A 1939 pet/kero posted by Gynther65 on July 23, 2006 at 03:20:01:
Pull the coil wire from the cap and hold within 1/8-1/4" of good ground on the tractor frame. Have someone to crank the engine with the starter
and look for spark from the coil wire. Do this as soon as the engine quits. Make sure the kill switch is in the on position. If there's no fire
remove coil cover and use a flatblade screwdriver to check the magnetism in your magnets. They should attract the screwdriver with some effort.
Hal
PS: If you have fire when it quits check your fuel for blockage.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
