Re: Super H clutch job
Posted by Greg Super H on July 29, 2006 at 17:38:43 from (152.163.100.65):
In Reply to: Super H clutch job posted by Greg Super H on July 29, 2006 at 15:08:18:
Thanks to everyone . However,the problem is still there. Let me try to give you all alittle more imfo.I did not replace the old pressure plate,but I did have to replace the throwout bearing and the pilot bearing.I did notice that when i tightened down on the presure plate to the flywheel the fingers on the pressure plate began to compress in to the center.Is this normal?
