Re: Super H clutch job
Posted by Janicholson on July 29, 2006 at 18:10:08 from (66.173.50.148):
In Reply to: Re: Super H clutch job posted by Greg Super H on July 29, 2006 at 17:38:43:
Yes it is. The problem may be that the combination of components is way different than before. Make the rod going from the clutch pedal to the little grank arm in the front longrer (maybe as much as an inch or so. The pedal should move only 7/8" to 1" away from the platform (measured at the point of contact) before it begins to feel firm and push the fingers farther in. If this still does not work, you may have put the disk in backwards and its drive hub is jambed against the flywheel (this does happen unfortunately) if so it must be turned around to correct the p[roblem or it will be ruined. Good luck, JimN
