H and Super H transmission gears
Posted by r4etierd on July 30, 2006 at 16:56:12 from (152.163.100.65):
I recently took a Behlen 9 speed from a !948 H Will it work in a 53 Super.If my memory is correct the constant mesh gear in a super is a little wider than one in an H, I am more concerned about the OD of the transmission bearings, don't know if there the same or not. My CIH parts disc doesn't cover Super H.I'm thinking if I use all the H gears and shafts it might work
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
