Re: H and Super H transmission gears
Posted by Dave Slater on July 31, 2006 at 06:34:54 from (205.188.116.133):
In Reply to: H and Super H transmission gears posted by r4etierd on July 30, 2006 at 16:56:12:
Yes, use all H gears including reverse idler gear.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
