Re: Would Like Your Opinion
Posted by Steven@AZ on August 11, 2006 at 17:21:49 from (24.121.155.253):
In Reply to: Would Like Your Opinion posted by Allan In NE on August 11, 2006 at 17:17:57:
Dad always told me that you need to plow in the fall, let it sit over winter - the freezing helps break up the soil. Then disk 2-3 times in the spring before planting. Dunno if it will work with your soil though.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
