Re: Farmall A - left side brake and seals
Posted by Pete7 on August 12, 2006 at 17:20:07 from (72.65.13.171):
In Reply to: Farmall A - left side brake and seals posted by Tom Stein on August 12, 2006 at 08:24:19:
Hi Tom....I did the left brake on my Super A a few years ago. I took the old seal to a bearing/ seal store. They measured the old seal and when I told them the shaft was groved they then suggested a slightly different seal. The new seal has the rubber resting little inboard ( or maybe it was outboard) of where the rubber on the old seal rested on the shaft. Saved me from having to sleeve the shaft. Might be worth looking in to.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
