Farmall A - left side brake and seals
Posted by Tom Stein on August 12, 2006 at 08:24:19 from (216.136.126.227):
I'm replacing the brakes on my A and have found the trans. seals to be bad on the left side. Lots of gunky grease in the brake area. The seals into the trans. are not cooperating to get them out.
Can I pull the seal housing off so I can punch these seals out from the backside??
My fear is the bearing and diff. will drop when I pull this off and I won't be able to get it back up into pos. when putting this back on with the new seals.
Any suggestions?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
