Re: confused about farmall M carb adjustment
Posted by Andy Martin on September 05, 2006 at 14:02:00 from (64.219.39.195):
In Reply to: confused about farmall M carb adjustment posted by garry lee on September 05, 2006 at 13:48:10:
The main screw at the bottom should be screwed in until the smoking stops.
However, the idle screw is an air screw admitting air to the idle circuit. If you screw it in, you cut off all the air and richen the idle circuit. The idle circuit does not affect the fuel much under load, however.
