Re: 424 Distributor
Posted by Bob on September 08, 2006 at 17:08:49 from (66.163.134.211):
In Reply to: 424 Distributor posted by Tim...Ok on September 08, 2006 at 13:39:39:
What's "going out"... the distributor bushings or advance, or the Pertronix unit????
I've never seen a Pertronix unit that's "going out". They DO fail once in a while, but typically, it's all at once.
What's your's doing?
If it is the Pertronix unit, you may be using a coil with primary resistance that is too low.
The "Ignitor II" units can handle low resistance coils, but the original Pertronix units can't, without the use of a ballast resistor.
Post back, and I'll try to help you.
