Re: Adjusting brakes on 300 utility
Posted by CNKS on September 10, 2006 at 10:58:10 from (204.249.178.135):
In Reply to: Adjusting brakes on 300 utility posted by Jimer on September 10, 2006 at 09:44:38:
Probably referring to the row crop, your specs are likely correct as the brakes are similar . I looked in my 460U's operators manual, and for some reason clutch and brake adjustments are not mentioned. As to the nut, the threads could be stripped, but it is more likely rusted in place. I have been able to get most similar things loose by soaking with penetrant and trying to turn both ways. Best to remove the shaft and clean the threads on either side with a bench grinder first, then concentrate on the nut. Some people use heat.
