Re: '43 Farmall H needs Overhauled
Posted by old on September 12, 2006 at 19:30:16 from (4.245.14.153):
In Reply to: '43 Farmall H needs Overhauled posted by Matt in PA on September 12, 2006 at 17:09:58:
You can pretty well figure at around $60-100 per hour for labor and 10-20 hours labor. Then you have parts which could be any where from $500 just for an overhaul or up to around $1000 for a rebuild. Overhual being new rings, rod and mani bearings, and a vlave job. That wouldn't include things like haveing the crank turned or other thing that it may need. If you do the work your self you can do it for around $1000 give or take a little depending on what all would need to be done by a machine shop. These numbers are only ball park and they maybe differant for your area
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
