'43 Farmall H needs Overhauled
Posted by Matt in PA on September 12, 2006 at 17:09:58 from (67.23.93.184):
Hello All,
I need to get my ’43 H overhauled. It was my grandfather’s, which he bought in ’47. I know it has never had any motor work done to it and it still has the original clutch, which is weak. The compression in the all cylinders is down around 95 psi and she fouls plugs and burns oil real bad. What would be a cost estimate to have her put back in sound mechanical shape? I was considering using the Case IH dealer Hoobers in Lancaster PA. What are your thoughts? Thanks, Matt
