Re: connecting one way ram
Posted by SDE on September 14, 2006 at 14:13:13 from (69.179.21.170):
In Reply to: Re: connecting one way ram posted by Wardner on September 13, 2006 at 22:22:51:
These rams came off a cornpicker. They have hoses attached to the bottom of the ram and have a vent cap on the upper port. I am installing them on a 3pt hitch. You are correct in that I wanted the lever to raise the 3pt when it was pulled back, instead of pushed forward. I will refill the hoses by removing the end and see if that helps. Otherwise I will return the hose to the other side of the outlet and learn to push the lever instead of pull it. Thank you everyone.
