Re: IH 340 industrial
Posted by JayWalt on September 15, 2006 at 03:34:31 from (24.223.138.48):
In Reply to: IH 340 industrial posted by Mark / Wi on September 14, 2006 at 13:28:40:
I would look it over real well. Check the hydraulic oil as well. IF this is any sort of seller, you should be able to get in writting a warranty for 2 weeks with the provision that the oil be changed (either by him or you, or both). That way if anything happens, you should be able to get a refund. Be honest with him about your concerns, tell him you've talked to profesionals (not me by any means) about it. Get a pressure gauge and check each cylinder for good compression. They are readily available for around $20 (a very good investment). They can tell you the difference beetween worn piston rings/sleeves, or bad vavles, or even a blown head gasket. I suppose one could remove the oil pan and check the mains somewhat, but that's going maybe a little too far? Also check grease fitting/joints for new grease. If the grease looks non existent, then thats another indication or a pooring maintained tractor. With the backhoe, check for slack in the swing chain (the chain that moves the backhoe back and forth) when the tractor is running (dont stick your finger in there!!) See if the tach works, so you can get a better idea of the tractors actual usage. Would be nice if you could use the loader/backhoe with a pile of dirt laying around. A weak hydraulic pump (which aint cheap to replace) may move the unloaded implements fine, but when loaded, they may slow down a considerably undesirable amount. Also, what is the asking price. Start low with your offer, you'd be surprised at what you can get things for when you low ball. My theory is you can always go up, cant go back down =) Hope I've helped in some way. I'm not so sure I got a good deal on my trctor. I'm sure some paint will change my thoughts on that =) Hopefully thsat will be next springs project.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
