Re: H Water Pump Rebuild
Posted by dcw on September 25, 2006 at 17:18:30 from (156.34.244.144):
In Reply to: H Water Pump Rebuild posted by IowaFarmall on September 25, 2006 at 13:34:38:
If the o-ring you speak of is inside the sleeve,that may be the old packing.Someone may have put an o-ring in its place,or if it is like mine was,it was packed so tight and was so hard that it resembled an o-ring
In the parts book,item 20 is the packing,if you order that part#,you'll get one piece,with the parts book saying ''as required''.I only put one in,it leaked,and trying to put more packing in while the pump is in the tractor is a chore and a half.
I hope this may have helped some.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
