H Water Pump Rebuild
Posted by IowaFarmall on September 25, 2006 at 13:34:38 from (65.110.227.126):
Everyone,
I am rebuilding the water pump on my H. When I took it apart, someone in the past replaced the greased bearings with sealed bearings which proves you never know what you will find! My question is, does anyone know what the number for the thrust washer on the Impeller is? My H parts book gives no number for this, only the complete Impeller Assembly. Also, is there any seal on the side of the water pump sleeve which sits back in the housing in front of the Impeller?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
