Re: Super M control valve
Posted by RoninKS on September 26, 2006 at 07:28:41 from (24.225.2.187):
In Reply to: Re: Super M control valve posted by D Slater on September 26, 2006 at 06:15:17:
I guess I should explain what I have exactly on the "christmas tree" in order to make things more clear. 1st. This Super M does not have a belly pump, or a lever that can be latched back. 2nd. Both of the "ports" comeing out the rear of the "christmas tree" have T's. 3rd. Dave, the "T" #2 hose is screwed into has 2 plugs in it, this port is the one that has pressure. 4th. The "T" that #3 hose is screwed into, also has a hose that runs to the rear/left port on the other side of the tractor (I think as a "return" and probably the reason for no pressure to the cylinder on that hose). 5th. The front/left port on the tractor has a riser pipe with a vented cap on it (I figure this is where fluid is added to the belly pump reservoir). I see no way to check the level of fluid in the reservoir the way things are set up now.
Also, if I remove the hose running to the left/rear port of the belly reservoir, how will any fluid return to the reservoir, as that is the only return line (that I can see) the way things are hooked up now (or, does the fluid even have to return to the reservoir in order for the cylinder to work)? Boy I feel stupid, RoninKS
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
