Re: 22-36 year
Posted by RUSS HAMM on September 29, 2006 at 10:46:25 from (63.245.179.200):
In Reply to: 22-36 year posted by Farm-all-the-way on September 29, 2006 at 10:35:26:
josh, i don't have my serial number list handy, but someone will. looks like it is 1930 or newer.it had an e4a mag on the earlier ones and then the f4 came late. you can run either one, the f4 being probably easier to come by with an automatic impulse. ih made these from 1929-1934. i would have to check the parts book to see what mag for sure. does it have the exhaust coming out the side or top? e-mail me if you want with questions. pictures, etc. always like to check out the old ones. good luck, russ
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
