Re: stop on spindle broke
Posted by Tallperson on October 14, 2006 at 09:29:26 from (165.170.128.66):
In Reply to: stop on spindle broke posted by 300Randy on October 12, 2006 at 08:19:57:
Like the guys said above, they are made of cast steel not cast iron.. They will weld just fine with 7014 or 7018.. 3/32 rod diameter and several passes. Clean the area thoroughly of grease and oil before starting your first pass. Clean all the slag completely with a chipping hammer and wire brush. I use a wire cup mounted on a 4in. hand grinder. It cleans up those little recesses very well.. Good luck..
Tallperson
