Re: Super-A ?...esp. Scotty or Banjo
Posted by Pa. Pete on October 19, 2006 at 17:50:11 from (207.7.183.166):
In Reply to: Re: Super-A ?...esp. Scotty or Banjo posted by daniel h. on October 19, 2006 at 17:36:42:
Thanks, buddy. You went to a lot of trouble.
There's no numbers on the loose washer/spacer, so who knows.
Guess I'll take out the axle. I gotta know if the inner spacer is there, or not.
