Re: Super-A ?...esp. Scotty or Banjo
Posted by daniel h. on October 19, 2006 at 17:36:42 from (66.226.34.159):
In Reply to: Re: Super-A ?...esp. Scotty or Banjo posted by daniel h. on October 19, 2006 at 17:04:58:
OK, I look in my old parts book, the pictures are a little better. It appears there should be the bolt, a lock washer, a special flat washer(20) the "lugged spacer" (17) another spacer washer (16) the inner bearing(22), another spacer washer (23), the tube spacer (24), the outer bearing (25) and an oil seal (26) and felt (27) w/ retainer. The spacer washers all have different numbers, so they must have different thickness, and with pulling one apart, I'm not sure which is which.
Daniel
