Re: Voltage/Current drain...
Posted by Janicholson on October 19, 2006 at 19:15:13 from (66.173.50.79):
In Reply to: Voltage/Current drain... posted by Russ Lowry on October 19, 2006 at 15:51:06:
A bad diode in the alt. will do that. Disconnect the alternator and see if the 12+ volts goes away. If it does replace the alternator. So far a good diagnosis, JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
