super a rebuild advice
Posted by werowance on October 23, 2006 at 12:06:59 from (216.145.90.20):
Hello to all, i have a super a that runs in the red on oil pressure when it gets up to running temp, i put new bearings in it this last winter and that had helped a little. however i plan to do a rebuild this winter and have a few options and need advice.
1. i have an old engine with a bent rod (piston locked up in sleve) crank is turnable, and i can get another rod for 20 dollars, it will need an oil pump.
2. i can rebuild the one i have, but have more down time.
some more questions i have are this...
on car or truck engines i always replace the oil pump, shouldnt i do it on my tractor? if so where can i buy one, is it dealer only? what about the bearings for the cam and the govenor, should they be replaced, and in trucks, i almost always replaced the cam, what about my tractor cam, and if so where can i find one? are tisco engine kits the best what do you all recomend?
any and all advice apreciated.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
