Re: Burnt valve
Posted by Doc Larry on October 28, 2006 at 20:04:33 from (216.146.101.227):
In Reply to: Burnt valve posted by Steve200460 on October 28, 2006 at 14:11:15:
I'm with Old & Rusty, it should start and run okay with 90 lbs in #1, I don't think you'll even notice it missing. Unless the compression drops off quite a bit more as you keep using this tractor, you may not even have a valve problem. I like the idea of checking your lash. Regardless, something else has happened to create the starting problem.
Larry
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
