Re: F-12 running rich
Posted by Fawteen on October 31, 2006 at 01:29:10 from (216.195.148.12):
In Reply to: F-12 running rich posted by Mr. Jeffries on October 30, 2006 at 14:45:51:
Float setting is pretty touchy on these old gals. I expect that once you get the carb apart, thoroughly cleaned, and reassembled with the float set correctly, your problems will go away.
That being said, chances are she'll ALWAYS run a little rich, as most were indeed dual fuel, and the carb is jetted quite a bit richer to allow for the kerosene/distillate it normally ran on. It should still run okay, not fuel-fouling plugs or smoking black smoke, but it'll definitely have an appetite for the gas.
