Re: Plowing with Fasthitch
Posted by Jeff P on November 07, 2006 at 08:48:53 from (207.28.116.1):
In Reply to: Re: Plowing with Fasthitch posted by Hugh MacKay on November 07, 2006 at 07:10:19:
Ok both IH manuals agree on the vertical float,(pin out of the bottom of the cylinder) but that's where it gets complicated. The plow manual says lock the arms pin in front hole, and the pin in front hole on the lateral as well (locked position). The Fasthitch manual says just the opposite, pins in back hole on the arms, and unlocked lateral as well. The fasthitch is equipped with traction control and the plow is steerable.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
