Re: Plowing with Fasthitch
Posted by Hugh MacKay on November 07, 2006 at 07:10:19 from (216.208.58.177):
In Reply to: Plowing with Fasthitch posted by Jeff P on November 07, 2006 at 05:12:57:
Jeff: I've never plowed with a fast hitch semi-mount, however there will be two distinct criteria depending on the hitch. The 300 and 400 tractors did not have draft control, only depth control. The later tractors all had draft control, and that will change the rules.
My suggestion is go to the proper operators manual for the tractor you are using. That in conjunction with plow manual should tell you how it's done. What Pete told by saying "float" is correct, however there will be a bit more to it than just "float". Semi-mounts are a bit unique.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
