Int'l 966 Hydro Will Not Move
Posted by Marvin on November 21, 2006 at 19:14:27 from (66.82.9.83):
When tractor is initially started--it will not move.
If you run the throttle up to about 1600-1700 RPM's, and move hydro lever forward,the tractor will then take off. If you idle it back down, it will work perfectly fine. Reverse works perfectly fine. As long as you don't shut it off for more than 30 seconds. If you let it off for more than 30 seconds, you have to repeat this same procedure all over again: running the throttle up to 1600-1700 RPM's and moving the hydro lever forward -- it then will move again. You then can go forward or backwards at any RPM. -- Just can't turn it off and start again. Any help? I'll be grateful!
