f-12 gas tank
Posted by roger in ky on November 24, 2006 at 11:19:54 from (66.38.36.31):
what determined if the f-12 had a overflow between the fuel pump and the carb that dumpted in the front of the gas tank at the top? will this effect the tractor running if i use a tank without the over flow.I see them both ways.all comments will be appreciated.
