Re: Super A - new pistons. won't turn
Posted by El Toro on November 26, 2006 at 05:15:46 from (152.163.100.65):
In Reply to: Super A - new pistons. won't turn posted by RCA 49SA on November 25, 2006 at 13:57:34:
If your oil rings were 2 thin rails with an expander this could be a problem too. If the butt
ends of the expander aren't butted together and the oil ring rails are installed this will cause the rails to protrude farther out. The rings if
installed correctly should be free to move within the grooves (lans) on the pistons. When you remove the pistons remove the piston rings from one piston and slide them one at a time into one of your tractor's sleeve. Then measure the end gap on each ring from that piston. It should be
from .010" to .018". If they're more than .018" the sleeve is probably worn. Hal
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
