Re: steering problems
Posted by Bernard le mécano on November 29, 2006 at 16:04:34 from (207.134.205.166):
In Reply to: steering problems posted by Dean D on November 29, 2006 at 04:57:23:
Hi, does the hitch work when the steering do not work? May be the oil strainer is full of dirt or ice. I've seen a trouble like that once, the steering turn on one side, then don't on the other. When you turn the sterring on both side, it have a small play to pull or push the cylinder valve. The end of the valve( thread end) have tendancy to wear and not open all the way. Put some drop of weld on the thead end and the trouble is fixed. Bernard le mécano Québec Canada
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
