Update - M is up and running.
Posted by unioncreek on November 30, 2006 at 20:26:36 from (64.126.155.42):
Installed the tuneup kit for the mag on my M and it fired right up. Moved the mag around so that it sounded like it was running nice and smooth. Guess you need to replace those points and condensor every 30 years.
I'll work on the timing more tomorrow, but what does everyone suggest on setting timing. Heard of just setting by ear, other's say the rotor should be just past #1 at piston TDC. Whats the consensus (sp?).
Thanks for all the help guys.
Bobg
