Re: 340 U Hydraulic Oil Change Update
Posted by Janicholson on December 03, 2006 at 14:57:21 from (66.173.50.104):
In Reply to: Re: 340 U Hydraulic Oil Change Update posted by suumoe on December 03, 2006 at 14:15:11:
I believe the complete Hyd system will be in place to allow the addition of remotes. This will (I believe) include a priority valve. Thus that is where I would look first.
If it is not equipped with a pump at the distributor, and has a seperate powersteering pump only, everything I have said is irrelevant. JimN
