Re: 340 U Hydraulic Oil Change Update
Posted by suumoe on December 03, 2006 at 17:38:09 from (76.4.93.74):
In Reply to: Re: 340 U Hydraulic Oil Change Update posted by Janicholson on December 03, 2006 at 14:57:21:
Jim,my pump is located inside the transmission case.
