Re: Cold, Ornery Diesel question
Posted by Brett in KS on December 07, 2006 at 18:52:07 from (205.161.18.127):
In Reply to: Cold, Ornery Diesel question posted by FC Andy on December 07, 2006 at 16:57:37:
Hi,
two 6 volt 800 amp batteries in series is 12v 800 amps. Voltage adds, amps stay the same in a series circuit.
Two 12 volt 800 amp batteries in parallel is 12v 1600 amps. Voltage stays the same, amps add up in a parallel circuit.
If you want more cranking amps, hook two 12v batteries in parallel.
Brett
