Re: Cub Hydraulic stuck
Posted by Kermit on December 09, 2006 at 16:02:59 from (24.24.33.193):
In Reply to: Re: Cub Hydraulic stuck posted by RP-40-9n on December 09, 2006 at 09:06:36:
I did put new Hydraulic fluid in when I filled it. I can't move the control arm, so I can't bleed off air that way. Seems more and more like something must be seized up inside.
If I take the unit off the tractor and drain the fluid, I should be able to push the cylinder pistons back and forth right? I mean they should be free moving w/o and hydraulic pressure working against them, correct? I'm thinking if I take the unit off, drain it, and I can't compress the pistons, something must be stuck inside. Am I correct in that?
Thanks,
