Re: Cub Hydraulic stuck
Posted by john cub owner on December 09, 2006 at 19:38:01 from (72.160.248.232):
In Reply to: Re: Cub Hydraulic stuck posted by Kermit on December 09, 2006 at 16:02:59:
There is a travel limit stop under the TC unit that limits the movement of the hand lever. make sure you have the arm inside its' brackets.
Y probably will not be able to move the arm with it drained. You have have one of the internal valves stuck. It should always have the piston retracted when removed and drained.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
