Re: IA,A,AV and B wheels
Posted by Roger Mills on December 12, 2006 at 06:29:29 from (204.13.130.86):
In Reply to: Re: IA,A,AV and B wheels posted by gene bender on December 11, 2006 at 17:56:58:
My FAA has adjustable front axle with flat hubs and rims with the U shaped lug and had 3 weights per side. The rear has a thin weight on the left rear steel center and the cast right center with no weight. The IAA has an adjustable front axle with stepped hubs and no lugs on the rims and no front weights. The rear has two thick weights on each side with the same centers as the A. There is no casting number on the thin rear weight. I have both the A and IA parts books and the IA does not show the flat hubs or rims with lugs and neither book shows the thin weight. The local International/Komatsu dealer has one of the thin rear weights and said it came direct from International in '47 on a white IA, (weight is white)???. You are right, AV has taller rims and they are the ones that have the V shaped "tabs"? to bolt them on with. The post I saw had some confusion about these tabs on small diameter rims so I assumed they were after market.
